Recently paid $2500 for gray market with front end loader and back blade. Good shape, stored under cover and most things work. PO informed me that when ordering parts a B7100 DT is the same. I am looking for a owners maintence manual and or in depth shop manual. I believe this was built around 1970. Has no gas pedal nor a shut off lever that you pull. To turn off I push throttle lever that is mounted on right side all the way forward. PO said he used the decompression lever which I have read is a bad thing to do. The number stamped on transmission is B7000 32768.
Cay you get these stuck? I have 20- yards of sand to move an its raining, the soil is Clay with standing water on top?
Thanks in advance for info
Best regards
Ron
Best regards
Ron
