Grapple does not close sometimes
top gnome
Dec 12, 2021
461
220
Fundy shore nova scotia
I have a lp sgc0660 grapple that is almost new i have maybe 3 hours on it. when I try to close the grapple sometimes it works fine other times it will not close and seems to try to close but does not move more than an inch. It actually did the same thing when the tech delivered the tractor. but started working normally again and the last time I used it it worked fine. today I had the issue again is there something I am doing wrong. I originally thought it was because I was trying to do a different loader function along with closing the grapple but today I was careful not to move the loader and just close the grapple and it would not close.
MOOTS
MX6000
Jun 27, 2019
2,196
2,739
Canton, Georgia
Disconnect and reconnect any lines for grapple. If that doesn't change anything, I'd look into the electrical side of the function. Assuming you have the LP kit.
Geezer3d
Kubota LX2610SU
Apr 22, 2021
225
224
Heart of the Catskills
Yes. There are solenoids that open and close the hydraulic valves when you push the buttons on the third function control. You should hear the solenoids click when you select them.
Chanceywd
Mar 26, 2021
797
781
central ny
While not the same setup I had some couplings I bought last year that I installed on a set up on my 8n. One of them out of the box just wouldn't pass fluid. The cylinder would extend some but not go back. It was a real pain until I figured out which one and once replacing it no problem extending or retracting.
So possibly you have a defective coupling since it is a new grapple setup?
Bill
top gnome
Dec 12, 2021
461
220
thank you for the replies disconnecting and reconnecting the hoses seemed to work, thank you but now my question is why?
6,100
Sometimes they look like they’re properly seated but they’re not properly seated. If disconnecting and reconnecting fixed it, it wasn’t fully properly seated.
BX23-S,57 A-C D-14,
6,239
ok, seems to be fixed but...did you check the oil level ? If it wasn't topped up after the grapple was added and was already a 'little' low.... you can get 'marginal' operation.
top gnome
Dec 12, 2021
461
220
I keep a pretty close eye on the level. when I put the BH back on I am a little over the full level. connecting and disconnecting the hyd. coupling seems to work.
top gnome
Dec 12, 2021
461
220
oddly enough it started happening again after checking the couplings, it seems to start and stop at random. sometimes fully opening the grapple will work sometimes sometimes slowing down the rpm will make it work. I wrote the dealer and they will send someone out but I hate to do that if it is something easy to fix on my own.
RKBHs59
LX2620 Compact Tractor
Apr 14, 2026
Rockerville, SD
I just had a new LX 2620 delivered, and the first time I went to use the grapple to do some serious work, I noticed hydraulic fluid was spitting out of one of the fittings attached to the grappler. Upon closer inspection, I found that the fitting was only hand tight and I think I had lost quite a bit of fluid before I noticed it. So I tightened all the fittings and went back and checked my Hydro fluid and it was low so I topped it off to proper levels and everything seems to be working properly now. My symptom was the grapple was opening when I went to close and lift.
