The rectangular steel plate on the underside of my mower deck is not bolted to the deck ,even though the bolt pattern appears to be able to line up. The plate can rotate 2-3 inches either way until it hits the bolts . it has been that way since i've owned it in 2006. Is it supposed to be bolted to the deck? The middle blade "spindle " has just a slight ability to wobble , but doesn't seem like bad bearings or whatever. hopefully the link works so you can see what i'm referring to . thanks, gary. <><
2nd photo : going green (rear axle ) !
