GPS Tracking advise needed
Bansil
B2601HDS with FEL/BH
Feb 26, 2024
15
Mnts. of NE TN
Plan to put one of the 12v ones on my new tractor, I am remote enough that airtags wont work. Or I don't want to rely on that tech, farms are too remote to get w/i 33 feet reliable
What are folks using?
something like this trak-4
5,628
Any that have 'plans' means they KNOW where your tractor is. READ their 'Terms of Use', especially the fine print. The car insurance OBD-II plugin for cheaper rate deal alllows them to SELL your info to anyone they choose.
yeah I'm 70 and cynical ,but really, read the fine print before you buy.
None of these tracker will prevent theft of your tractor. It's easy to haul it into an enclosed trailer and poof, tractor is now MIA.
Consider making it harder for the thieves to drive your tractor away. Simple stuff like remove battery or primary fuse, remove a front AND rear tire, sit on blocks, put note on it saying' plug BOTH GD tires buy more wheel nuts'. Drop loader to ground, same with 3PH blade. Put on blocks and remove valve stems from the other 2 tires. Essentially you want to make it a real PITA for them to steal it. OK, so YOU have to spend an hour to get it 'up and running' but... at least it's still there.
All 'trackers' consume a lot of power and the more 'pings' the less time the battery lasts,even less in winter ( below 50*F )
5,081
...or, you can simply carry the KTAC insurance if you financed...and sleep well at night.
Bansil
Feb 26, 2024
15
Mnts. of NE TN
I did get the KTAC!! it has saved my buddies in the past, they made sure i got it.
You both our correct, thank you! I've never had a new tractor....kind of like how you worry about new babies :p
Save the monthly bill for moar fuel
So a mod can delete this to save site resources
Thank you
6,524
Buy (and attach) a post hole digger and drill the deepest hole it will bore. Leave the bit in the hole. Remove a fuse. Cover it with a camo tarp. There are no easy answers, be creative.
5,628
or drain the oil and coolant out of the tractor(remember you did this...) so when bad guy steals it,engine locks up when he goes to use HIS new toy.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
681
155
Rising Sun, MD
And you still have your home owners insurance if it was on your property.
mikester
M59 TLB
Oct 21, 2017
3,867
2,507
www.divergentstuff.ca
I use a locked barm and keep my machine out of site.
If someone is serious about stealing your machine it will be dragged onto a flat bed in a few minutes and it's gone. Pros have no need to waste time trying to start it.
That's what insurance is for.
3,521
The best thing would be to jump the "seat safety switch" and wait for them to post a "My tractor won't start" thread here. :unsure:
