GPS for spraying
JRS
40
49
Central Texas
Does anyone use a gps that not only shows speed but also shows ground covered when spraying fields and pastures? I’m looking for a reasonable priced unit with good accuracy.
BX23-S,57 A-C D-14,
5,926
'reasonable' ? hmm.. how about free (well, $20)??
If you already have a tablet or smart phone, all you need is to add a WIFIswitch on the sprayer system. An 'ap' in the computer sees when the sprayer is on, does some 'math', updates the screen.
Any good programmer can cut the code in less than a day.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
482
117
NZ
JRS
40
49
Central Texas
We have 90 acres of mostly pasture and a 17 acre field that will be mostly wildlife food plots.
Just Looking for what works for others with similar situations.
10,041
This is a good thread. I'm interested to see what you choose and how you like it when spraying.
jimr63
M5-091HDC, L47TLB, L4701F, ZD1211-72, GR2120-54, RTV-X1140
Jun 24, 2015
120
47
SOMD
I’m using an Agricision OnTrak with my iPad and it works very well. It’s about cheapest system I could find that paints a picture of ground covered.
Thunder chicken
M7060
Dec 29, 2019
300
123
Northern ontario
That looks very cool. Far more advanced and cheaper than some stuff we use in airplanes for surveying! (Mind you we aren’t looking for 20cm accuracy in those specific applications!)
SteveBX23
LX2610SU; BH77
May 23, 2021
180
305
South Jersey
Sprayers on fine turf, such as golf courses, have gps systems that shut it down to the nozzle when spraying different areas. Cost savings are suppose to equate to +/- 15% on yearly chemical expenses. But might be a different application from what your looking for. I do know the gps setups for those application are pricey. Foam markers and/or tracker dyes are utilized as well.
cswenson25
RTV-X1130
Feb 21, 2025
Frost Inc. has a Kubota UTV that is fully equipped with a sprayer and GPS. Pretty cool setup for turf and golf courses. The nozzles turn on and off depending on the mapping system and even the spray rate changes with speed. Love it.
