glow plug indicator
texoak51
kubota m6800hd, modern 7' highway special brush hog, box blade, duel 3point hay
Feb 26, 2014
owasso,ok
Hello all, new to orange tractor talks and have a question. I posted same on tractorbynet .com but as yet no replies. I have a 2002 kubota m6800 that doesn,t seem to have a glow plug indicator although it does have glow plugs. I have checked on kubota illustrated parts list electrical and one is not shown altho it shows the relay switch and plugs. Anyone know if in fact this tractor has no indicator or am I just missing it somehow.Thanks
8,773
On the lower right side of your dash do you get three lights that come on when you turn on the key?
I do believe that it should be there, possibly a burned out bulb?
texoak51
Feb 26, 2014
owasso,ok
Thanks for your response and yes there are three lights in that location for easy checker but they are engine oil pressure light ,alternator light and pto light. All bulbs are working
8,773
Interesting... The wiring is the same on the M9000's so maybe one of those guys can tell you more.
I don't remember who on here is lucky enough to own one...
My next Kubota will be a big M! ;)
plusmoins
M7950DT cab & 595 Allied fel, 2 y.cu snow bucket
Jan 19, 2014
St-Felicien, Qc, Canada
maybe it's like my M7950 On the right side of de steering column i see a domed chrome ring. It's the glow plug indicator, Not a bulb but à resistor element. After near 10 sec. this element coming red. Turn on the glow plugs and look inside de hole of the ring.
Bulldog own a M9000
texoak51
Feb 26, 2014
owasso,ok
Thanks, I went out and checked and I have no chrome ring on my steering column. I have put my glasses on and searched thouroughly ( I think) and have concluded one doesn,t exist which is totally weird considering it does have glow plugs. Don,t really need one as it has never failed to start even at 20 or so degrees. Mainly just curious as it should have one by my way of thinking.
8,773
Your tractor is new enough that it's probably automatic glow plug operation and requires no input from you besides turning the key. ;)
texoak51
Feb 26, 2014
owasso,ok
Hmm, never heard of auto glow plugs but you could be right. Thanks
SteveF
BX25
May 15, 2013
307
Huntingdon, PA
Welcome to OTT.
This may be a dumb question but do you turn your key right or left to activate? Kubota uses both positions.
texoak51
Feb 26, 2014
owasso,ok
All positions are turn right. In my owners manual there are 4 positions shown at switch although there are no correspopnding logos actually at the switch. They are off, on, preheat, and start. There is no actual stop at the preheat spot ,I just hold there a few secs and hit start.
AD4GC
M6800
May 17, 2015
Bee Lick, Ky
I'm a bit late to the thread, Yes your tractor does have glow plugs, but no it does not have an indicator. Turning the key half way between on position and the start position will activate the glow plugs. I have the same issue and checked with a test light. I am going to install an indicator (12V LED) in the dash just to make sure they are getting current, it wont tell me they are working correctly, just telling me they are getting juice.
