Glare from canopy
smittydog27
L3901DT, MX5200DT, Case 450, 1450 dozers, Case 530 const. king backhoe/loader
Dec 11, 2018
22
Huntington
Ok. So for those with canopy And rops lights on their tractor. Do you have glare? Bugs? Any issues that one can learn from? No one really mentions issues like that (that I have seen). Let me know
BigG
Sep 14, 2018
1,951
767
West Central,FL
The bugs and glare have both been mention.
Do a search for - ROPS lights bugs - and there is alot to read.
Palmettokat
M6800, B2710, L6060, Volvo 5 ton excavator and implements.
Apr 21, 2020
251
53
South Carolina
I have a open station M6800 with canopy. Used it for field work mostly. The front lights did a good job but I wanted better. I added trapezoid lights to the tubing on the bottom of the canopy itself. This placed the lights about two feet in front of my face and I had no glare. Bugs...and more bugs in warm or hot weather. If I were needing that set up today would install a fan to keep them off and some fresh air blowing on me. I think you have a valid concern about possible glare on lights mounted on rops behind you. I know with my glasses light behind me causes me issues.
Depending on the reason you are considering adding more light you may want to look at the current head lights. Some use a simple bulb and you can install higher wattage and maybe even a Led bulb.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
1,855
933
Near Lancaster, PA, USA
I never had a canopy, but here's a thread where I gave my 2 cents on ROPS mounted lights. Probably has some similarities. Check post #11.
smittydog27
Dec 11, 2018
22
Huntington
Chim,
How did you mount the lights in the tube?
NHSleddog
B2650
Dec 19, 2019
2,149
1,828
Southern, NH
I have mine mounted to the front of the canopy. I do not get any glare from where they are located. I haven't noticed the bugs being any worse than any of the other lights.
chim
Jan 19, 2013
1,855
933
Chim,
The cubes are mounted to a small clip angle I made with a 1/4-20 tapped hole. I drilled a 5/16"-ish hole in the tube. With the cube pre-aimed and mounting tight, a 1/4" bolt was inserted through the hole in the tube and threaded into the clip angle.
A little more info on the setup:
