The head ended up being cracked down the middle chamber after it was magnafluxed. The head was repaired with stitching pins and the pre-chamber and valve seat had to be removed to reach the ends of the crack. I don't have an after pic but stitching pins were first put at a 45* angle into the end of the crack down both bores and were completed all the way between it. The chamber had a little bit of rust damage from the coolant but I doubt it will affect much since the crack is fixed and a new valve job was done.
A new valve job was done and all the valve were cleaned up.
Motor is now assembled and done!
So to sum it up:
Head cracked
Block starved of oil from cam plugs
#3 piston rings cracked
The only thing I'm not sure of is if the coolant hurt the #2 injector but DFIS said they can rebuild them for under $100.
