Getting ready to install wheel studs
Jim L.
870
172
I don't have a comment on the loctite.
However, the torque will need to be checked often with new studs as they will elongate.
BruceP
G5200H
Aug 7, 2016
852
373
Richmond, Vermont, USA
It should not be necessary but it would not hurt to use loctite red to help the studs stay put. Do not forget that previous to using any threadlocker compound you MUST prep the surfaces. (thorough degreasing) I use brakeKleen and an old toothbrush for this task.
QUESTION: why are you replacing wheelstuds?
9,578
cavjock23,
Just curious, what is that hub off of ? :confused:
It's not an M6060. ;)
cavjock23
M6060,709 pull shredder, offset disk, Pallet forks, Box Blade
Apr 9, 2017
47
Houston, TX
'Sounds like it may be a bit late if you have already bought new parts, but you could buy a thread chase or die and try cleaning up the old ones?
It was real bad.. I had to weld nuts to back out the old studs..
