gas problem
pfont
b2650, bx2380
Jan 22, 2022
nys
I am having fuel issues. replaced two filters with kubota fuel filter used on b2650. I still have problems: tractor sputters and stalls as if fuel is bad. I've used algae cleaner and diesel treatment. This is the third time this has occurred. Tractor is bx2380
Mark_BX25D
Bx25D
Jul 19, 2020
1,787
1,306
"gas problem"
" I've used algae cleaner and diesel treatment."
Gas or diesel?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,044
Williamstown Ontario Canada
Is there any correlation with outdoor temps.?
I would be inclined to completely drain the tank and lines, buy fresh diesel from a busy truck stop and try it after a through bleeding to get all old fuel from the system.
Tell us about the history of the fuel you are using........... when was it bought and where. A fuel blend for summer use cannot be made good for cold weather by adding chemicals especially when your engine has a modern emission system.
Dave
SRRGC1
BX1870-1, BX23S TLB, RTV XG850, MX5100DT
Jan 6, 2021
219
76
Bloomsburg
Could be fuel pump issues OR some sort of blockage in the fuel line or tank restricting fuel flow. Have you tried to blow air back into fuel tank through fuel line? Do you use a fine screen fuel filter when refueling?
BAP
Dec 31, 2012
2,957
1,060
If you are putting gas in your diesel tractor like your thread title is suggesting, you have some serious problems. Not only will your tractor not run well on gas it will do some serious damage to your engines components.
