G5200H 48" mower help
NELS
b7200 g5200
Oct 25, 2012
17
Watertown CT. USA
I have a parts manual but don't have a service manual and am looking for help on the mmm gear box lube. How much and what weight? It appears to have two fill bolts at the rear of the case and I would think that the top one is for filling and the bottom one is to indicate the correct level but really don't know so am looking for help. Anyone know the answer. I've gotten so much help just reading on this site and thank everyone fo rtheir input.
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
353
Homer City, Pa.
SAE 90 API GL5 gear oil for the mower gear box, get yourself a quart and you'll be fine.
Big Kahuna
Profnohair
L1500, 42" bh, box blade, G6200HST, Mahindra 450 with BH, FEL, etc.
The entire owners manual is available at kubotabooks.com under the mowers and catchers section. It is a three part download due to the size limit. It has all of the info you are looking for. (,32 qts of 90 weight oil is indicated).
If you have problems accessing the site try again as the site has a data limit that gets reset and is then available again.
The tractor operators manual is available on the site also in the tractor section.
NELS
b7200 g5200
Oct 25, 2012
17
Watertown CT. USA
BK and Hair, thanks for the replies. Got the manual and it shows exactly what I needed to know. The two plugs on the back of the gear box are for filling and draining the unit and not for filling and level as I thought.
Again guys, thanks for your time and expertise.
