g2000s front axle loose
5,460
2,155
it is the same as my old g1900 which i sold. Shoulda kept it but couldn't--the offer to buy was too good and i already had another mower which is faster funner cheaper (free + repair cost) easier to maintain fix and all parts are readily available
they can be a royal pain in the backside to fix!! Or they might be easy. Dig in and tell us how it was. Has the grease fitting under there ever been greased?
u will have to take the deck out then lift the front end of the machine and support it so you can see what's going on. It may be bearings. Or it might be the whole axle + the support. The axle was STUCK in the support on mine, the bearings were loose/worn and I had to replace the support and bearings and shims. Expensive but worse yet was having to get the old parts out. I had to CUT them out, which was not fun and I have the tools to do it properly. if you don't have the tools don't mess with it. The support goes through the frame and if you damage the frame you will be doing some welding and metal fab. at that point (if it comes to it) it's better to just remove the engine so you can get to everything, and with it off you can pressure wash it too so it's nice and tidy.
3,445
Butch: “You shouldn’t sugar-coat it like that Sundance (lugbolt)…. tell her like it really is!”. :ROFLMAO:
5,460
2,155
there's a difference between a technician and a service writer
the writer tells you mostly what you need to hear in a way you need to hear it
the tech tells you what you need to know in tech terms that you may not understand, don't want to hear, or, frankly, just may not like. But you are guaranteed to learn "something".
there was a reason I wasn't a very good service manager/writer.
3,445
I’ve been both…. technician…and service writer (manager).
The service writer SHOULD be a good listener. He should let the customer describe their complaint WITHOUT trying to diagnose the problem himself. He should accurately describe the customers’ complaint in the service-request….and let the TECHNICIAN diagnose the problem and propose a fix/repair.
It was my experience as BOTH… that when a service writer takes it upon himself to decide what the issue is…. that the next error made is for the service writer to decide the solution. I.E. “TUne up”..
Then…when the tuneup is done and the customer takes the vehicle home and the problem persists…. guess who gets the blame? (I’m thinking now of the time this exact problem occurred and I performed the complete tuneup…. valves adjusted, timing set, spark plugs replaced, filters changed, etc.…. when the real problem was that the car would not start first-thing in the morning …but would start and run just fine later in the day.
I was fired over this issue when I argued with the svc-mgr that the svc-writer was the cause of the unhappy customer. (The problem was a cracked ignition coil that would make contact/complete the secondary circuit when the temps rose later in the day…but which would not in the cold morning.)
The svc-writer was the mg’rs protege’. I just happened to pack up my tools and go to work at another dealership that very same afternoon…and by chance….the unhappy customer brought the car to the second dealer the next week. I couldn’t BELIEVE IT when I recognized the car.
The second dealerships’ svc-writer simply wrote it up as “hard to start” and further described the problem disappeared in the afternoons.
A-Ha! I sprayed freon on the coil and it failed to spark…but a heat-gun on it and it fired just as it should! Replaced the coil and problem solved. The customer is who told my new employer that I’d been the technician at the earlier dealership (Willingham Toyota, Pasadena, TX). and that it was me who also resolved the issue at “Main Street Toyota, Houston) only a few days later. LOLLOL
Anyway… the most common problem is the initial-conversation when the service writer (or doctor or other provider) leaps to a conclusion instead of listening to the complaint. Communication….I.E…. LISTENING…is the single most-common human failure we make.
