Hi All,
I have a G2000 that has some oil dripping on manifold, I pulled the valve cover (see pics), and wanted to check the gasket, found a couple breaks in a soft gasket except for about 3" or 4" that was stuck in place and hard. It was located where the red arrows are pointed on the A side. question, does anyone know if the burned area due to the gasket leaking or valve(s)?
Note: below the burned area, is the exhaust manifold.
Thanks in advance.
Kendall
Thanks in advance.
Kendall
