I have a G1800 with glow plug light NOT illuminating (at the dash) when ignition switch is turned to "pre-heat" position.
Ignition switch has been tested in all positions with positive results.
The glow plug light bulb has been tested; it is good.
I have continuity from the ignition switch (in "pre-heat" position) to the Combination Box through the 1 25RB circuit.
The 15 Amp fuse is good.
I have continuity from the glow plug light to the Combination Box through the BrR circuit.
I have current from ignition switch (in "pre-heat" position) to the the glow plugs at the engine.
Any thoughts and or suggestions as to why the glow plug light is not illumination?
Thank you.
Thank you.
