I have M5400 Kubota 2wd tractor with 1200 hours. Made in 1990's obviously no DEF. It has the common canister particulate fuel filter (see picture), but no fuel water separator. I just got into some fuel with water because my Bobcat skid steer was throwing water in fuel code and i was having to stop and drain fuel water separator frequently. Same fuel also put in my kubota, but it is running fine.
I went by Kubota dealer yesterday, and they confirmed this unit was made without fuel water separator. The MX5400 (4wd) does have a separator, but not my M5400.
Wondering if anyone has added after market separator?
Since it has 20+ years of running flawlessly, a mechanic friend of mine advised me don't try to fix what isn't broke. He thinks that engine is so old school bare bones that it will handle a small amount of water and just burn right thru it. I just ran it on nearly continuous 14 hours doing spring planting and it never missed a beat with same fuel that was throwing water code with skid steer (there was water i could see when i drained the separator on skid steer- not just a false sensor).
I also have 1980's Iseki tractor and 1999 Ford pickup diesel neither of them have separator and neither have issue. Wondering if the old diesel engines more resistant to water issue whereas newer computer controlled machines are much more sensitive. I don't know if that even makes sense given all diesels still run basically the same.
