I have a M5700 Kubota tractor, and the fuel tank has partially collapsed. Does anyone have any ideas on how to fix this?
Did the tank collapse because the breather was blocked which would cause a vacuum or the straps were too tight or?it' not to bad. I tried to heat the tank in the hot sun then tied a small rope around the fuel cap and pull up on it to pop it back up. It did not work. I have had someone suggest I put very hot water in it and then try to pop it up. I am afraid that I might have to take the tank out to do that and I would hope there would be another way!!!!!!!!
