fuel shut off solenoid picture
twomany
B7200
Jul 10, 2017
793
138
Vermont
Many two wire fuel shut off solenoids are energized to CLOSE. Make sure you know how yours operates.
Three wire solenoids are often energized to OPEN. One winding to draw in, a second winding to hold .
jhn39747
Kubota l2800
Dec 26, 2021
central Florida
Good comment. This is a two wire connector. It is energized with the ignition switch and a click sounds as to energize the solenoid to open allowing the engine fuel and to run. Turning the switch to off stops the motor. I do not know the important answer to the comment.
Fedup
278
96
Winchester
Do you have a question? Does your tractor have a problem with the operation of this solenoid?
5,422
2,118
and some of them have two coils, one to pull the solenoid in, the other to hold, but are self-grounding (through the body). ;)
twomany
B7200
Jul 10, 2017
793
138
Vermont
Might be some info in this thread
I didn't read it, but usually good stuff there.
