fuel line leak
Wood1083
BX2370
Jun 23, 2016
Jamestown, SC, USA
I have a BX2370, without the mower deck. i had a stick go up and rip a hole in the fuel line right before the under carriage fuel filter. The hole is in the line between the fuel tank and the first fuel filter. Any one have a P/N for the fuel line and a procedure to replace it?
2,749
If I remember correctly - that is a very shorrrt piece of hose, and on top of that, a true PITA to get to.
Is the "hole" in such a fashion that you could cut it across that spot and add a double barbed union? OR better yet - get an 90 degree ball valve and place in that spot. IT will save you a lot of headache later when changing filters.
Wood1083
BX2370
Jun 23, 2016
Jamestown, SC, USA
Yes, the entire length from the tank to the filter is probably about 16 inches at most, but looks like I would have to disassemble half the tractor to get to the bottom of the fuel tank.
I was actually thinking about installing a shut off valve for that exact reason. The hole is about 3 inches before the fuel filter. I'm not sure what the fuel line diameter is. looks like it could be 3/8, 5/16.
2,749
"looks like it could be 3/8, 5/16."
I think it measures out at 8 mm - however 5/16" will fit perfect.
I am going to do something like that .......one day soon!
Wood1083
BX2370
Jun 23, 2016
Jamestown, SC, USA
I went with a 3/8" barbed splicer. it was a good snug fit. Had to cut out about 1" of the damaged line, but there was enough slack to make up the difference. Appreciate the help. Now I have a place to install a shutoff valve later.
