fuel gauge
jeftech
m9540
Feb 27, 2017
florida
m9540 fuel gage is inop I tested the wires from the cluster to the sending unit and are good. tested sending unit and ohms change when moving up and down so I replaced the cluster and gage still reads empty. just could use a littlehelp on what to do next also has new sending unit
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Best to get a manual with the wiring diagram, there's a 9540 low profile supplement on the net which has a wiring diagram which would be very close I expect, check that you have variable resistance at pin 18 yellow wire at the plug going to the cluster.
www.kubota.cz/data/manualy/m9540-low-profile.pdf
jeftech
m9540
Feb 27, 2017
florida
was able to get back to it today and found that a my 5v is good to the sending unit until I plug the cluster in. I have had new parts bad before but never new cluster guess going to have to break down and get the manual to find my problem . the diagram that you shared was close but not close enough thanks
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
329
94
Bagley, MN, United States
I have most of the M9540 manuals - here is the info for testing the fuel sensor - PM me and I will try to provide more info. The manuals are huge so posting them or emailing them in there entirety is probably not possible.
jeftech
m9540
Feb 27, 2017
florida
ohms are right on the money more than likely just going to wire in an aftermarket gage thanks for all the help
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
Did you check for resistance in the ground circuit from the gauge to the tractor chassis? I bought a B7500 this summer that was doing all sorts of weird things in the dash. Temp gauge correct some times, not others. Glow plug light on when headlights were on. It turned out to be a bad connection of the ground circuit where the wiring harness plugged into the back of the dash.
