Front wheel servicing on kubota b8200
Stephen Watts
B8200 version D
I have just been cleaning this up: see image. In removing two of the bolts the whole thread came off/out.
My question is: do I just go ahead and replace all of them? See the wear and tear on top image. Or can I get away with just replacing the two that have come out? Do they just need cleaning up? And also do I need to get specific thread or is it universal thread to most bolts? Another question I have which is a bit of a theory one: are there stronger ways of attaching this?
3,191
I would just get the OEM parts unless you can fully identify the bolt type and thread. Kubota often used some Japanese automotive bolt identification numbers that were just a number (like 7) stamped on the bolt head. (Supposedly they set a torque standard on that number on the wrench used to install it at the factory.)
But you will need to at least match the thread pitch so the lug nuts still fit all the bolts.
11,490
There is nothing wrong with that stud, put it back in.
If you want it to not come back out the next time you pull the wheel just put some thread lock on the stud when you put it into the hub.
And all the bolts on that model are metric fine and extra fine thread.
