I am a newbie with a new L3800. I cut an area with a lot of steep slopes and I think I need front weights. My question is how much weight. Thanks
I've seen your pic before and really like the idea too. I was thinking of making a weight and mounting just like you did, but I'm not going to be tugging a couple hundred pound weight every time I take the FEL off/on, so that's why I was asking about the additional weight - once on, it's staying on.Suitcase weights have to come off when you put the loader on. I built the pictured bumper weight from a 20' stick of 1"x4" bar stock, and leave it there. The weight is about 240lbs. Steering - even uphill - is no longer a problem with my 5' bush hog.
The weight issue is a consideration. Kubota says the front axle is only good for about 2600lbs - you have to get the info from your dealer. Just the loader empty adds about 2200 lbs to the front axle, in addition to the normal weight of the tractor. If I leave the weight on, and put a thousand pounds in the bucket, I'm WAY over the limit. You have to keep in mind that the CG of the loader, load, and weights is all well in front of the front axle.
So I don't drive fast on uneven ground. Never with a bucketful. But for normal running around with an empty bucket I seldom use even 5th, and don't worry about the weight
