Front tires for a b8200 2w drive
Machelle
Kubota B8200, for bush hog and box blade
Jul 26, 2017
Ragley
I have 6.50 x10 tires on the front and can't find them anywhere . One blew out and they save they are discontinued. What can I use as a alternative tire.:-(
2,869
For your machine - 2wd - any tire that fits the rim and fits your checkbook will work;) No need to get the old style tire, unless you are trying to be OEM,
Any tire style will work fine - If you have a FEL, get a tire that has a good load rating. You should probably get two, should not be too awful expensive for the fronts.;)
