Front pto
ripper 1000
B7000 building a fel
Jun 12, 2012
11
B.C. Canada
Hey guys im new on here. I just bought a b7000 n im in the middle of building a fel, like everyone else i cant find a used one. my problem now is i cant find a coupler to go on the front output shaft on the motor to connect a pump to, any input would be great. I bin lookin around in here but can't find what i wantto fix my problem. Thanks. Great site awsome infoe n pics i will try n post some later on my progress.
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
369
9
Homer City, Pa.
Wow, you're in luck, I just put the finishing touches on rebuilding a B219 FEL that fits my tractor B7100HST, I know it's hard finding one. Well here's the numbers and yes they are still available, just bought new chains and the gear to drive my pump. Any help you need just drop me a line!
Big Kahuna
CHAIN COUPLING ASSEMBLY Note * Kubota numbers
70050-00056 Roller Chain Times 2
70050-00110 Sprocket Shaft
70050-00111 Sprocket W/18 - 22 Spline
70050-00112 Sprocket W/9/16 Bore
ripper 1000
Jun 12, 2012
11
B.C. Canada
Thanks guys 4 the info, but mine is an 18 spline with a big nut on it. My dealer told me the same thing, that it was bolted on with 3 bolts. I thought cool easy fix i get home n look no bolts just a big nut. He also told me the parts u show Big Kahuna r obsolete. Dont know what to do now
Big Kahuna
Dec 23, 2011
369
9
Homer City, Pa.
Ripper 1000, How can they be obsolete???????? I just ordered them 3 months ago, I just reran the numbers, here's the price for each item.......... go to Messicks and get them.
Your tractor has the 18X22 spline, this is correct, the upgrade to the larger 30mm spline was done in the early 1980's, you changed the pulley with gave you a 3 bolt hole pattern in turn the new larger 30mm spline bolted right over top the old 18mm spline, I was told the 18's were stripping out (not enough surface contact) and that's why the larger "upgrade" came out
Big Kahuna
70050-00056 Roller Chain Times 2 $20.78 Each
70050-00110 Sprocket Shaft $105.36
70050-00111 Sprocket W/18 - 22 Spline $100.03
70050-00112 Sprocket W/9/16 Bore $63.05
Big Kahuna
Dec 23, 2011
369
9
Homer City, Pa.
I don't think I ever seen or herd of just the shaft. You could always just plumb it in the tractors hydrualics, it would be slow but would still work.
Big Kahuna
P.S. Hey some FEL's are listed for sale that fit your tractor on OTT, check them out.
