Front loader Quick DisConnect plate for 3pt
ichversuchte
Enola, PA USA
Has anyone every hooked up 3 pt on the front of the tractor. I have a backhoe on my b2650 and use it often when clearing out areas but really need a rake as well, much easier to disconnect the loader than the hoe.
Example attachments
https://www.skidsteersolutions.com/quick-hitch-fixed-3-point-adapter-eterra/
https://www.skidsteers.com/3-point-adapter-attachment.html
Cheapest option > https://www.palletforks.com/skid-st...3zqDNa7IxdxEgrIydJkcHqq5glBkqmbwaAj0kEALw_wcB
With quick hitch > https://www.palletforks.com/tractor...EBkbABUv-vM9rl4yASEClL-O76rIOXf0aApSOEALw_wcB
3 Point Attachment Adapter Skid Steer Trailer Hitch Front Loader case https://www.amazon.com/dp/B07449SDC5/ref=cm_sw_r_cp_api_i_FzvbEbCTM6XDV
I don’t own any titan attachments, are they decent?
War Eagle
2012 B3000HSDC and Allis Chalmer 5020
Jan 15, 2017
102
21
Nampa, Idaho
I have a B3000HSDC and have converted the FEL to SSQA using the ATI adapter for this model tractor.
I have the Titan Fork lift adapter for SSQA and I have the Titan landscape rake for the 3pt and both implements have worked well for me.
My forks are rated for 2K and that exceeds the lift capability of my tractor and they were the most reasonably priced unit I could find on the market.
The rake is a 6FT model with adjustable wheels and it has been a winner for me as well.
8,722
I made the same unit as the titan one with the quick hitch.
$180 total, SSQA Plate, Harbor freight Quick hitch, 10 min of welding, done.
Not too bad of a price for the Titan unit.
mikester
M59 TLB
Oct 21, 2017
3,874
2,520
www.divergentstuff.ca
I made my own to run a rear 3PH snowblower up front. Made it from 0.25 flat plate and flat bar I had available in the shop. If you have the equipment you can fab it easily at low cost. I used a hydraulic motor to run the PTO shaft. Works well.
jimr63
M5-091HDC, L47TLB, L4701F, ZD1211-72, GR2120-54, RTV-X1140
Jun 24, 2015
120
47
SOMD
Example attachments
I have that one and like it. Built very well and lets me use my 3-point stuff up front when I need to.
