Front End Loader Dimensions
schmellba99
L3800
Jun 4, 2012
95
Is there anywhere to find dimensions of different models of front end loaders?
Example - to compare something like an LA351 or LA352 to an LA525. The 525 is for a newer model tractor than what I have, but the HP range is the same - I have a line on a LA525 loader and am wondering if I can make it fit my B2410 without too much extra effort (knowing that the mounting brackets will likely need to be modified).
My internet skills are weak in this department - any help is appreciated.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
You may wish to investigate loaders intended for B series tractors. The LA 525 is for the L series whose undercarriage is very different.
9,594
The issue isn't the size of the loader as much as the lack of frame to hold the loader on your B2410.
The difference between the loader that's supposed to go on you b2410 and a newer loader is you need a subframe, newer tractors have the subframe built into the tractor already.
