front axle pivot greasing
Dan Williamson
L3400F
Jul 1, 2012
Pride, LA
Back to my no-zerk front axle pivot bearing......
If I replace the breather plug with a zerk, and pull the adjustment screw out of the front end while shooting it, will that work?
(2006 L3400F 2wd)
Bluegill
Jan 11, 2012
1,560
Success Missouri
That should work for the front bushing.
But is there a pivot bushing behind the front axle, like on a 4wd?
Breeze
L3700, Box Grader, 60" Bush Hog, Rear Grader Blade, York Rake, Boom Pole.
Dec 24, 2010
149
Virgin Islands
(2006 L3400F 2wd)
I looked at the manual, again L3700, and what you propose might work on 2WD. Behind the adjusting screw there is a Thrust Collar (probably have to remove), the bushing and an oil seal. There is one of these assemblies to the front and rear of the axle beam, pictured on page 6-S17
Now when I look at the manual, it does not show a grease fitting on page 6-S17, servicing 2WD type but on page 6-S7, Front Axle Rocking Force, it shows a zerk and a breather plug for 2WD? It would seem that if you have a breather plug, there must be a grease fitting??
Also, when you reassemble it is necessary to:
Jack up front axle side
Set a spring balance to the front axle flange
Measure the front axle rocking force (Spec = 11-26 foot pounds)
If the measurement is not within spec, adjust with the adjusting screw
Tighten the lock nut firmly
Hope this helps. On a 4WD this MUST be greased as you have a ball bearing on the differential gear assembly and mating pinion teeth.
