Freeze Plugs
thejebber
siler city, north carolina
I purchased what I was told was a Gray Market Kubota. I think I'm the 3rd or 4th owner. I'm not sure of the model number, there wasn't one when I bought it. I believe it is comparable to an L3500. It is 2wd and a 3 cyl diesel. 1908cc is stamped on the engine. The plate on the side of the engine is unreadable. I'm looking to purchase freeze plugs as mine started linking with winter. I would also like to know the model if possible. Thanks for your help.
bosshogg
2004 L3400F w/ FEL
Aug 16, 2012
231
Hartford, SD, USA
I believe you would be able to measure the freeze plug opening diameter and get your freeze plugs with just that measurement. It will be in mm not inches. You could also measure the cup depth. I am assuming these are friction fit type frost plugs although some older tractors had threaded frost plugs I believe.
