Flickering LEDs
weldguy
BX2200
Apr 13, 2014
21
Columbus, Ohio
I decided to swap out the 1056 headlight bulbs on my BX2200 with brighter LEDs. The first pair I installed flickered at a high rate. I tried adding 50 ohm resistors with no difference. I returned those LEDs and ordered another set advertised as "with proper resistance to avoid flickering." Nope... the new ones flicker just as bad. They flicker with and without the engine running.
Has anyone tried LEDs that don't have the flickering problem?
Hugo Habicht
G1900
Jun 24, 2024
1,322
1,911
Ireland
I replaced the bulbs with LEDs as well and they flickered pretty badly. I left them in and the flickering stopped after a while. No idea why.
The engine was running, I do not know if they would have flickered as well with the engine stopped.
4,827
Just a thought, but could the flickering be related to "tractor vibration” somehow? (instead of being electrically related)
Hugo Habicht
G1900
Jun 24, 2024
1,322
1,911
Ireland
Very good point, but he wrote the flickering is also there when the engine is not running.
I would find a tractor that is vibrating when the engine is off deeply worrying 😅
lynnmor
B2601-1
May 3, 2021
1,745
1,547
Red Lion
I just installed 10 4 foot LED shop lights in my basement and had flickering. At first I thought it was just cheap Chinese lamps, but after some investigation I found a poor connection where the breaker clamped on to the bus. A new breaker and cleaning of the bus fixed it. Check for bad connections anywhere on the circuit.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
341
246
NH
You will notice the flicker in an LED more than an incandescent light because the LED turns off immediately. An incandescent light will remain bright for a short while because the filament is still hot.
Flakily electrical connections will be noticeable with an LED that you may not notice with an incandescent.
Cheap LED's also have cheap internal electronics which are not filtered well, and the voltage fluctuation can be seen.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
634
662
Amsterdam, NY
If you’ve checked all the connections and they are tight with no corrosion it could be voltage drop.
Measure the voltage at the light fixture. If the voltage measured is significantly lower than the output, or if it falls below 11.5 volts, excessive voltage drop is occurring. Could be inadequate wire gauge or bad wires.
Watch this vid.
Voltage Drop Explained
Then again it could be cheap LED's.
4,827
hahaha….missed that.
too much/not enough Coveffee 🍻
4,898
I was going to say a poor connection or a high resistant ground, but somebody already said that
BX23-S,57 A-C D-14,
6,160
Polarity?
not really possible, LEDS ,being diodes, don't take kindly to 'reverse voltage' and poof, let out the 'magic smoke'. good LED lights( those with 2 wires) will have a diode bridge in them to prevent that from happening.
Since most LED 'offroad' lights are good for '12-24' volts, the PCB of parts has been poorly designed. White LEDs require 3.4 volts to light up. 3 in series need 10.6, so a small resistor is need to drop the '12v' battery down. 4 LEDs in series needs 13.6. which a 12v battery can't light up. Now depending on the design and parts, it might just come on briefly,then off, try again, and the cycle repeats. Easy to test,put 2 batteries in series and see if the LED flashes or comes on steady. I'd have to see what's inside or a real schematic to say why they flicker. I know the ones I've built do not flicker. 3white LEDs in series with a constant current supply.
7,430
When I installed LED headlights on an L1500 a few years back they didn't work until I reversed the polarity. There was a thread about it on this forum.
