Pull the power lead from the headlight switch and now feed the switch directly from the battery.
No more flickering....
I do not know your particular model of Kubota, but many of the early years ones had alternating current supplied to the lights. This was done because it was more efficient electrically.Pull the power lead from the headlight switch and now feed the switch directly from the battery.
HI DaveI do not know your particular model of Kubota, but many of the early years ones had alternating current supplied to the lights. This was done because it was more efficient electrically.
Owners who installed LED bulbs soon find out they do not run well on alternating current
Dave
I am not a BX expert but in general, when you do as you have, you have discarded a significant portion of the dynamo output.HI Dave
That's why on my BX1500 they were flickering, ran direct from the battery, for constant voltage
It is likely possible to rectify the headlight AC and direct it to charging the battery.
Dave
Which of your two tractors are you referring two?Hi Dave
I don't understand your statement. could you explain?
Thanks
