Flat Out tire sealant
2,601
Used this sealant in front (old dry rotted side walls) that went flat in a week.
Has held pressure for a week now seems like it is working out.
Does anyone know what sealant can be used in the rear wheel that has fluid in it? Probably water or windshield fluid. I have a slow leak on a rear tire that is also old and dry cracked. I may just drain the liquid out and then add sealant (5 gallons?)
7,296
Russell, maybe you'll have to drain the fluid, install the sealer and use the tractor for a while. Then put a tube in with the WWF in the tube.
2,601
We just replace tires when they get that old. The traction with new tires is amazing
Yea but I am cheap and don’t need much traction for what I do.
I have considered new tires and may go that route
