Just did my 50 hr service on B2650. I tried to tighten filters to spec per the manual. The two hydro filters had an overnight drip, may have been residual from taking filters off but I went ahead an torqued them a bit more. What is "too tight" and what issues will that bring up? This morning no drips. Oil filter was a bear to get to and reinstall due to routing of cables and tubing, had to flex some of those but got it in and tight and luckily no leaks there.
Engine oil sure was black for only 50 hours of light use. Is that just break in oil or a characteristic of diesel engines/oils? For the break in I tried to keep it around 2000 rpms, now that I over 50 hrs is that still a good working speed or should I up the rpms closer to max or max only when necessary?
