Filling tires for ballast
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,297
184
Coyote Flats,Texas
Mike_B
How much Dawn did you put in what size tires? I have 16.9 X 30 rear tires that I'm going to add H2O to.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Check with the surplus buyers and sellers in the area. We have some that have the steel cut-outs from some large equipment manufacturers.
The ones I found were near round and thick steel, 4" and up. By then welding on studs they make great wheel weights. Price is generally steel junk price. I then arranged to attach one to the wheel as with wheel weights, but then hung others outside of that using a big center bolt, threaded into the inside weight. lacking that source, round steel "bar stock", 8" and up in diameter works, but you need a power hack saw to "slice" off what you need. A pain in the neck to remove in case of a flat tire, but otherwise worked great. For a 28 HP tractor, three of them per side really helped.
