Had a thought last night.
I remembered that sometime when under power the the joystick would stay slightly in the down position when pushed thus allowing the bucket to slowly go down.
Raised the bucket, wiggled the joystick to make sure it was in nueteral position, measured the height.
Got up this am, and it only lowered about 1".
Conclusion, weak spring in on the shuttle valve.
Two choices.
1. Ignore it.
2. Locate a rebuild kit for it and fix it.
Also had another thought, but didn't follow through. Thought about raising the bucket, turn engine off and disconnect the quick couplings to rule out leaky cylinders, but opted not to. Didn't know if I could disconnect with pressure on them so I put that one on the shelf.
