Error-20 L3940/update
L3940, error-20 . Had a stick break speed sensor on right side of trans, replaced, hold down travel speed and display mode buttons while turning key on, brings up menu to clear code .... done ...... error code comes back tractor wont start..... checked wiring, have continuity on 2 of the wires to ECU black w/white stripe and orange, red w/2 white stripes no cont. Same wire goes to shifter and another sensor I think on top of trans one at shifter has cont other does not ...... when I clear code it says clear I push and hold disp/mode button it says "push sw" I do it says "ok"
I'm lost help please anyone tractor is stuck on a job for a wk and have work with deadline
UPDATE; I've gotten a shop manual and done all the diagnostics, everything cks out except red w/2 white stripes (power) to sensor no power, manual says " ok if has 0.5 volts ... But doesn't say if it has no voltage what to do.....
I tried the emergency connector which I assume is for this type situation, it still won't start still says error-20
I narrowed it down to the ECU got a new one $873 plus shipping it wasn't the ECU SOMEONE PLEASE HELP ME
