5' sickle bar mower. Minimum PTO HP is 12 to operate. Has a double action cutter so I will almost not get jammed, even when cutting wet material. Has hydraulic lift cylinder. Can operate straight up in vertical position and down at 45 deg. category 1 hitch, weight 440#. Making it perfect for mowing ditches and pond slopes.
This is in excellent condition. The rod holding the cutter bar is missing and a wire is in it's place.
Located in zip code 66064, south of Olathe, Ks. about 25 miles. $1700
Send a PM and I'll give you a phone number.
Here's a link for additional info: http://www.enorossi.it/en/project/bf-bfs/
