Engine?
leesmith
11
Buchanan, Virginia
I have what is believed to be a Kubota Diesel engine numbered V1702-68752. Can anyone identify this engine as to horsepower, age, applications, similar engines, etc. Thanks.
9,584
Pictures would help to tell you if it's a IDI or a DI engine.
rodbuilder
17
Dixon, Ill.
That would be something you'd find in a Bobcat 743 skid loader. You can also use a 2203 in one.
9,584
That's making a huge assumption, there is several versions of the V1702, and only one of the versions was used in the 743. ;)
leesmith
11
Buchanan, Virginia
Unfortunately the engine is locked up. It was left out in the weather for some time and water entered the cylinders, rusting in the pistons. I am trying to figure out if it is worth anything as it sits or should I just salvage whatever parts I can and recycle the wrecked parts.
leesmith
11
Buchanan, Virginia
Did have the head off. Soaking the cylinders for 2 weeks...no movement at all. Appears to be rust above the pistons. I imagine it would have to be re-sleeved.
9,584
Rebuilding that engine is not very cost effective, I know I have one.
Rebuild cost is in the 2k range and that is if there is no physical damage to any parts.
Parts can be worth something, it's just selling them can be hard.
