Engine RPM Not Coming Down
mculik5
B2650 TLB
Sep 22, 2020
32
NJ
Experienced something strange on my B2650 today...
I was dumping of bucket of dirt on a pile and had the loader up in the air. All the sudden, the engine RPMs jumped about from about 1700 to about 2000. I finished dumping, backed up, lowered the loader and idled the engine.
But instead of the normal 1100 RPM idle, it was idling at 1300 RPM. After about a minute or so, the idle had settled back to normal.
Then, a bit later, the same thing happened. At that point I had the RPMs up higher and I idled the engine with the loader in the air. The RPMs only came back to 1700 with the throttle completely closed. Interestingly, as soon as I touched the loader to bring it down (with the throttle closed) the RPMS dropped right down to normal 1100 RPM idle.
Nothing visibly wrong with the tractor that I could tell and the engine was running completely fine at all times...just weird RPMs.
Any ideas? Thanks. Happy Easter if you celebrate!
4,472
Is your machine new'ish?
Could it be that "re-gen" thing that happens every so often?
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
That is weird. Only suggestion i have is to lubricate all of the parts of the the throttle connections. They get sticky. Can't figure out connection to loader position unless there is a stick in there somewhere.
#40Fan
460
318
The hand throttle isn't directly connected to the linkage at the engine.
Here are a couple pictures. First shows the hand throttle that you'll move while in the seat. The piece circled in red (in both pics) acts upon the piece pointed out with the green arrow. You'll notice in the second picture, the rod goes through a couple holes and has a spring that helps with pulling it back when the hand throttle is moved. I'd check that area out for binding.
As for why it goes back when you operate the loader.....Maybe there is some binding that only happens when the loader is off the ground. Does the bucket sit level when fully lowered?
Joisey
Kubota L47 TLB
May 31, 2015
191
124
Wild, Wonderful West Virginia
The only time I had an experience with a diesel that wouldn't return to idle as normal was with my VW diesel Rabbit. I was driving to work and about half way thru a long left hand bend when the engine just took off on its own. I went from 55 mph to almost 70 when I pushed in the clutch. By that time I was thru the turn and the revs dropped to normal. I thought it was a fluke until it happened the next three days on the way to work, but never on the way home.
It turned out that the engine was spewing fuel vapor that collected in the air box behind the filter. There were drain holes to the individual intake port runners at both ends of the air box. The vapor would condense into liquid and lay in place until I took that long left hand turn which had a fair bank angle to it. The bank angle caused the liquid to run into the intake runners, giving the engine more fuel and causing a runaway.
I checked the compression and it was 50 pound above minimum, but the engine had begun to use oil, so I pulled it and had it bored and had new valves and guides installed in the head. The problem never returned for the 200K I put on after rebuild.
I'm not saying THIS is your problem, but it may be something to look at. Best of luck to you.
