Engine error code
MGMike
L6060
Jul 28, 2016
Oakpark VA
My L6060 tractor started showing an engine trouble light and "Error 3080". The engine runs normally. I phoned the dealer, who says it's a "generic" code related to intake air temperature, but it also might be a loose wire or bad sensor. So I cleaned and checked all the electrical connections; found nothing suspicious, and back-flushed all the radiators, but the light and error message won't go off. I have redlined the tractor until this is rectified.
What does this code specifically mean?
I have a high-end Autel OBD II reader but can't find a recepticle on the tractor; does it have one? If so, where?
How can I clear the error to see if it recurs?
Many thanks for any guidance,
M
9,586
It's not OBD2 equipped, it proprietary.
It's not a radiator issue, it's a intake air temp issue, so either it has a pre heater or something else is wrong that's either letting it suck cold air or mush less likely to warm of air.
MGMike
L6060
Jul 28, 2016
Oakpark VA
Wolfman: Thank you for the quick response.
The L6060 does have a pre-heater for intake air.
I'm going to let it cycle once through the PM and see if it resets.
M
