Engaging PTO
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,377
1,648
Kalamazoo, MI
Not sure about a sweet spot but I engage PTO at idle and then bring up to full rpm after the implement is spinning. For shutdown I return to idle, let the implement settle down then disengage PTO
2,940
It’s what my Owner Manual also recommends.
2,940
Kubota 4
Read your Owner’s Manual:
random
Nov 2, 2020
717
401
NC
Even easing off the clutch, the PTO implement seems to start abruptly enough while in idle. At speed would make me rather nervous.
kubotafreak
Sep 20, 2018
1,019
372
Arkansas, US
As low as you can go without running risk of the machine dying. Every machine and implement is different. Example is a spreader wont take much to start spinning, and could easily start at idle. A heavy brush hog may actually kill the engine if you start it at idle.
