Electrical problems Kubota ssv 65
duane04
Kubota ssv 65
Jul 31, 2023
So I've got this kubota ssv 65 skid steer it's about 2012 year or so. But I parked it like two days ago and when I went to start it it just makes a little buzzy noise almost like static and the display screen just flashes around a little but won't try to crank over. Anyone got any ideas I've already looked into all the fuses ect and none of those were bad and I didn't see any obvious problems with the wiring. Any help appreciated.
cthomas
LX2610 HSDC
Jan 1, 2017
845
560
La Farge Wi
Have you checked battery cables and load tested battery? Performed visual inspection?
8,591
#1 Battery cables or connections
#2 Dead battery
duane04
Kubota ssv 65
Jul 31, 2023
agree... replace battery and probably cables, especially if originals !
I've tried jumping it already and nothing different so far and the battery terminals look fine so I guess Ill check for load next thanks for the input tho
5,598
if you jumpered battery to battery, you've kinda confirmed bad cables........
..providing the old battery didn't kill the new one..
duane04
Kubota ssv 65
Jul 31, 2023
Ok guys so apparently my multimeter is bad plus my jumper cables are also fishy because I jumped it the other day and no difference and now I put the jumpers on it again (jumping from a Ford f250) it actually tries to start now And I guess it's time for new cables and multimeter because it said the battery had a little over 12volts all along which is not true so I'm sorry for wasting y'all's time over this but thanks for all the input.
