Dumb question regarding SSQA attachments
KubotaHawg
L2800DT, LA463, Landpride ΒΒ1260, RCR1260, ZG222
Jan 9, 2022
107
168
NW Arkansas
Considering getting a grapple, and know I will need to install a third function kit and SSQA adapter to my LA463 loader on a 2007 L2800. Currently has pin on factory 5’ bucket.
Question is this: if I install a SSQA adapter, I am assuming that is not compatible with a pin on bucket? So unless I buy a new bucket that is SSQA compatible I will have to unpin the adapter and reinstall the old bucket with the pins?
Removing pins is not a big deal to me—when I bought this tractor 5 years and 200 hours ago I replaced the old pins. Old ones hadn’t seen grease in a long time so just replaced them and have kept them greased every 10-15 hours as recommended. Old ones were a bitch to get out but after cleaning the sleeves thoroughly the new ones slid in without any resistance.
I’d rather not buy a new bucket as well (if possible). I would probably use the grapple more than the bucket but would certainly like the ability to change out quickly.
Thoughts?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,773
2,216
Western MT
You can attach a SSQA plate to your bucket. You would probably cut off current connections and weld the plate to the bucket.
John T
2017 BX23S
May 5, 2017
1,169
699
under a rock
I would just buy an SSQA plate and weld it to the back of the pin-on bucket...
Of course this would take a little fab work but nothing too fancy. (cutting off the pin mounts)
I'm sure any welding shop can hook you up If it's something your not comfortable doing yourself.
