Hello colleagues. Can anyone tell me what exactly the KUBOTA K-OBD ACE diagnostic kit includes? These are the numbers I find: 07916-81100-changed with: 07916-81102-changed with: 07916-81103, but there is no information anywhere about what exactly is inside (what cables, software, hardware). Best regards
designed to help farmers / fleets that run and repair our equipment.
Not cost effective or realistic for a single unit owner IMHO. Costs a couple thousand dollars. You can buy with or without laptop, etc... so you customize the parts and pieces you need based on what equipment you are operating. For example construction equipment and Ag. equipment can use different cables and plugs. Your dealer should be able to tell you what bits and pieces will be needed for your fleet of equipment. I have seen a page of options of add ons and do dads avaliable.
Its lets us read codes, make resets and diagnose problems. Helps diagnose and repair.
What it doesn't do is let you into the ECU to change programed parameters calibratetions like shutting off sensors, doing DPF deletes, change max rpm's, injector settings, etc...
