Deck bearings
CHolmes
G4200 T1600 L3130
Apr 10, 2011
20
Bridgetown Nova Scotia
I need deck bearings for my T1600H. It has a 44" deck but not sure of the model as there is no tag to be found. Does anyone have the correct part number for spindle bearings? Better yet a FAG number?
dieselhillbilly
rogers, Ohio
We are doing deck bearings as you call it on ours . We have a T1600H with a 44" deck. Ours has three blades and the model number is RC44LT. Hope this helps.
CHolmes
G4200 T1600 L3130
Apr 10, 2011
20
Turns out that is what it is, My deck is rough but repairable. I also need the sheeves for the top of the spindles. $50 at Kubota whick is far away. Anyone ever used an aftermarket or sheve from another make that will work?
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
I needed sheaves for a Kubota 347-8 deck I rebuilt a while back, I was able to get what I needed from Grainger Industrial Supply, Below is the link to the thread with some pics and also a link to Grainger.
http://www.orangetractortalks.com/forums/showthread.php?t=4223
http://www.grainger.com/Grainger/sh...nsmission/ecatalog/N-ar3?contextPath=Grainger
Surplus Center also list sheaves(pulleys)
My deck originally had the sheave with a seperate tapered bore bushing so that is what I replaced it with.
https://www.surpluscenter.com/sort.asp?catname=powerTrans&keyword=PPT1
I also replaced all the bearings as they were standard 1" bore flange bearings and I manufactured my own new blade adaptors, The link showing my new blade adaptors is below.
http://www.orangetractortalks.com/forums/showthread.php?t=4403
I measured my bearings was able to purchase a set of 6 bearings(1 upper & 1 lower for each spindle of a 3 blade deck), I purchased all 6 bearings on eBay for less than $50.00 including shipping.
I think that many of the parts for the decks like the bearings,sheaves/hubs,blade adaptors are SAE and are usually sourced by the mower manufacturers, Making them standardized means that the same bearing/shaft/sheave/hub/blade adaptor can be used on a variety of applications and lessens the amount of different parts needed in a manufacturing process.
