I recently bought an old Jocobsen T422D mower with a Kubota D950 engine. The previous owner said the engine was running great 2 years ago when the transmission went out on the mower and he parked it. I charged the battery and it turns over but I can't get it to run.
This is what I have done so far.
Bled the fuel system (bled at the filter, inlet hose at the pump, bleeder screw on pump, and injector lines at injectors)
Removed and checked glow plugs (all 3 glow red when touched directly to a battery)
Checked power at glow plugs using dash button (only getting 5-8 volts but the indicator will eventually glow red on the dash)
Before I knew better....I sprayed a little Ether in the intake but it still wouldn't fire off.
What's my next step to getting this engine to run??
