D850 tractor engine
Dallasdj
US
Can you interchange parts from a d850 marinized engine
With no water port in engine block to a d850 tractor block with water
Port and use waterpump off from d950 engine
Thank, Dallas
Eise
B7100
Jun 25, 2018
38
Groningen, The Netherlands
From what I've read; the block is identical except for the intake manifold, exhaust manifold and waterpump. I've never seen a marine version though.. so I can't give you any guarantees, let's hope someone else knows for sure!
9,785
Yes you can swap parts between the two versions, you will just need to check that gaskets and ports match up. ;)
