I have a Bobcat mini excavator with a D750 in it. Originally motor was super hard starting and smoked when i got it running and had no power. I did a compression test on the one cylinder that I could get the tool on and it was low. Doing a compression test on all the other two cylinders is impossible due to the angle while they're in the machine.
I sent the cylinder head out to be rebuilt, (came back with no major concerns) put on new piston rings, installed new injectors and reassembled it. It's still very hard starting and while cranking, billows out a ton of dark grey smoke until it finally catches and then smoke diminishes from the exhaust but doesn't completely disappear. I have some blow by, not a lot, but still more than I think it should have. The machine now actually has power. I still hear a little chattering so I think the valves need to be adjusted a little more.
Does this sound like a fuel issue because of the hard starting? or does this sound like something else? Suggestions welcome and appreciated. Thanks
