D1462 injectors
Marmaduke
L1-225 Sunshine wth 4 in 1 bucket
May 25, 2021
Australia
Hi Folks, I have an L1-225 sunshine grey import in Australia with a 3cyl D-1462-DI engine. I need new injectors and local parts suppliers can’t identify the part number. Extensive internet searches have not turned up any certain answers. Can anyone tell me what injectors are correct or where to order them online? Thank you, Mark.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
Instead of checking with a parts supplier try checking with a diesel repair facility. I had a gray market Mitsubishi and one of the local "big rig" diesel repair places was able to rebuild my injectors like new. It turned out they were a common Nippon Denso model.
Marmaduke
May 25, 2021
Australia
Thanks Roadworthy, I’ve been to see my local diesel service and overhaul place but my injectors were badly damaged during removal and don’t have a part number on them.
I actually bought a new set from a grey import specialist near me but the new parts are different (5/16” or 7ish mm too short).That’s the trouble for me now, having what is thought to be the correct part but it’s not right for my application.
Marmaduke
May 25, 2021
Australia
Dafyddjns
L1-235 tractor
Mar 1, 2012
Brisbane Queensland Australia
I have a Kubota L235DT tractor and need new injectors. Kubota Australia don't want to know me. I have have a part number stamped on the injector. It is made by Nippon Denso.
Injector stamped 4230 12H
Nozzle stamped DNOPD55
Any ideas as to equivalent injectors and wher new ones can be purchased.
It would appear my engine is a D1462 model and is indirect injected, with a short fat injector.
I recently replaced the head but have run into trouble with the injectiors.
3,094
Kubota USA lists two part numbers
15271-53000 (1 required) and 15271-53020 (two required)
these people may be able to help you with the Nippon Denso part numbers.
On my L185 the ones I got from the dealer ca in a nippon denso box (I think). I think they were the same part numbers and could look at the old parts and boxes this weekend if you want me to.
the only difference between the two is the fuel line connection at the top.
