I've searched and can't find the answer. What is the operating coolant temperature for a D1105-T with a 71*C thermostat? What temperature is considered overheating?
Overheating is generally considered the temperature at which the coolant begins to boil.I've searched and can't find the answer. What is the operating coolant temperature for a D1105-T with a 71*C thermostat? What temperature is considered overheating?
If it's got a 71*C thermostat, that should be it's operating temperature.I've searched and can't find the answer. What is the operating coolant temperature for a D1105-T with a 71*C thermostat? What temperature is considered overheating?
That's what I was thinking but wanted to confirm. Converting to Fahrenheit and per the workshop manual the thermostat starts to open at 158*-162* and is fully open at 185*.If it's got a 71*C thermostat, that should be it's operating temperature.
And engine coolant temperature will be higher depending on ambients, engine load, and where you measure it.That's what I was thinking but wanted to confirm. Converting to Fahrenheit and per the workshop manual the thermostat starts to open at 158*-162* and is fully open at 185*.
