Cylinder Reseal/Repair PT1
3,317
And PT2:
3,317
And PT3:
L35
Jun 13, 2010
642
704
CT
I took the time to watch these today, even though I have rebuilt most of my cylinders in the past. Excellent explanations and camera work, if anyone has any questions about rebuilding, here is your instruction manual!
ken erickson
Nov 21, 2010
1,314
2,317
Waupaca Wisconsin
i agree , well filmed and explained. I learned a lot, thanks Lil Foot!
3,317
You're welcome, folks. This guy worked for his grandfather's shop, then his father's, then his own, before starting his home shop & internet business. He is very experienced in machining & hydraulics, and does pretty good filming & editing too. He also does kind of a travel log and cooking series that I don't follow much. I follow his machining stuff pretty religiously. He often does non-conventional setups & methods, like someone else I know. (me)
Blkvoodoo
B2400, LA352, RC60, Cammond Box Blade
Mar 27, 2010
143
Zebulon NC
I respect what Adam (Abom79) does, and how he was able to obtain the seals, but most of us likely don’t have the time or measuring resources to source seals individually (in some cases there may not be enough of the seal to measure or determine it’s shape properly)
Ive repacked dozens of forklift cylinders of all sizes and types, the thing I learned is if you can source the OEM, in most cases that’s the best source.
Granted, many OEM seal kits are unreasonably expensive for what ever reason, but reliability and fit is usually better.
I sourced the kits for my own LA352 loader from Messicks, at one time they were $99 ea, they’re now $37ea and they are now in my cabinet waiting for me to install them.
id also check a reputable shop (like the guy in the video) and see what their cost is for a repack, Guy near me is $100 ea per cyl up to a certain diameter then it goes from there for a basic repack, seals, tear down,cleaning, reassembly. Any machine work is extra of course.
3,317
Glad to hear it. :)
I have all the measuring tools, so I can, and usually do, buy all the seals & o-rings individually when I rebuild cylinders & valves, but there is a lot to be said for spending the extra bucks and buying the OEM rebuild kits. Almost always more expensive, but simple, quick, & easy.
netxtown
68
Blue Ridge, Tx
Ok....losing some hair.
My bucket's hydraulic is 3" diameter. Checking McMaster, the spanner wrench for a 3" cylinder has a 5/16 pin. But!!! I just happened to have some 5/16 rod - and it won't fit in the hole. I tried 1/4" - - - still too big. Closest i can get to fit is a drill bit that is about 6.5mm (31/128" on digital caliper).
It makes some sort of logical sense that the "hole" would be a metric measurement.....and of course, that seems to be an unpublished spec. Are there tools that are specific to Kubota cylinders?
3,317
I use a set like this:
It has different hooks, radius arms, and pins, and covers most stuff that I need.
When I rebuilt the backhoe, I made this up:
BX23-S,57 A-C D-14,
5,902
I would assume that Kubota would use metric for their cylinders,and follow Metric 'standards' for whatever they're designing, in this case ,cylinders. Heck, I assumed my BX23S was 100% Metric, as Japan is....Oopsy... the BX23S is a 'hybrid', which is really crazy and really bad from any way you look at it....designs, manufacturing, parts, repair, etc.
as for the spanner wrench... well it's Imperial ( 3" ) but WHOSE 'spec' says the pins are 5/16". I see a lot of small 4cylinder, compact cars with 4 bolt rims and a lot with 5 bolt. WHOSE spec decides that ?? Shouldn't the 'standard' be 4 bolts ??
netxtown
68
Blue Ridge, Tx
The ones that really drive me crazy are 6 bolt wheels but only 5 spokes! I'm thinking it is a conspiracy to push some of us over the edge...right on off the edge of this flat planet.... ;}
joea
B21 TLB
Aug 2, 2020
95
9
Marbletown NY
Very informative. I was rebuilding a cylinder and wanted to verify which way the lip of the seal below the wiper went in. Found it entertaining as well as informative.
I was also pondering some nicks in the rod. Not bad really, but he seemed pretty down on any damage at all and I suspect the seals will fail early. It's only the stabilizer cylinder for the backhoe, but, at $95 for a seal kit from Kubota, not easy to shrug off.
A new rod from Kubota runs about $350. How do I get in touch with him, Abom79, to get a quote?
