Hello guys.
I've run into a big snag rebuilding my L175 and was wondering if I could get some advice. I don't know how I missed it before other than carelessness but as I was cleaning the deck to reinstall the head this afternoon I noticed the liner on Cyl 1 was sunk farther into the block than on Cyl 2.
I have no luck with this machine.
Cylinder 1
Cylinder 2
You can see where the old carbon build up used to be and where it's been scraped clean by the rings. The exhaust valve guides were loose in the head so can infer that it was overheated hard and I imagine that's when this liner shifted. Another concern is the connecting rod having impacted the bottom of the liner though I heard no knocking so I think I'm good there.
The correct path is obvious, renew the rings and liners (probably the pistons too with my luck). I'm already well over budget for this rebuild and parts (including pistons) would be $400 at Messicks plus whatever the machine shop costs. On top of that it'd mean stripping down and removing all of what I just put back together and then some. I could just kick myself for not noticing it before. I just can't figure out how I missed it.
The pistons still move freely. I don't know about the compression ratio but it seemed to run ok before it was disassembled and I don't see any serious scars in the liner walls. My fiscal sense is sorely tempting me to find a way to tap the liner back into place and put it back together with my fingers in my ears. My inner mechanic is screaming just as loudly that even if that worked it's going to cause more problems later and there is only one way to do it right.
What do you think I should do here? If I do the renewal I can probably get the liners out but I lack a press large enough push in the new ones. I've read Aquaforce's thread and understand the liner needs to be bored out to the piston size and the deck surfaced. Is there anything else that needs to be done? Is there a better (cheaper!) way to do it then sending the block off to a machine shop? Can I reuse the old pistons (though the top lip on #1 doesn't look good)?
Thank you in advance for any help,
Matt
Cylinder 1
Cylinder 2
Matt
